跳转到主内容
加入维修社区 - 创建账户
Launched in October 2014, identified by model number CHDHA-301.
Why won't the charger fit into my GoPro Hero?
My GoPro Hero is dead and needs to be charged. Unfortunately, every time I attempt to connect the charger to the back of the board, it doesn't quite fit into the slot. Can anyone help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Take a second to look at the back of your Go-Pro. Look at the slot that the charger typically goes into. Does it appear to be aligned with the casing? If not, this could be the first problem. In order to fix this you must pop off the back of your go-pro. Take into account that your Go-Pro does not actually come out of the clear skeleton case. Instead, the grey or black chasing should come off with a little leverage.
If you're having issues doing this, look up the device page on Ifixit and the guide for this will be there.
If everything looks aligned, and there are no crumbs or small bits clogging it, then look at the charger itself. Ensure that the end of the cable doesn't have anything stuck in it (i.e. food, dust). If it does, take tweezers and attempt to remove the small pieces.
这个答案有帮助吗?
得分 0
添加一条评论
There is no small bits of food are stuck inside my chargers ng port at all,
it's just my my charging won't fit instead de the. Hanging port,
And sometimes I had to hold press the charger in to the charger port till it's start to charges . And I try doing it again to hold press . But it's does not work anymore,
这个答案有帮助吗?
得分 0
添加一条评论
my GoPro didn’t come with a charger so I bought one for My GoPro and it won’t fit in the hole any suggestions what I should do oh and it’s low on battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zoe Tuggle 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 8
总计 4,177
