跳转到主内容
diagnostics led meaning on macpro 2013
i have a macpro 2013, it stop coming up and when i remove the cover, the diagnostic led show now sign of power entering the system at all. and when i press the button beside the strings of led, two came up. what could be wrong? pls help....
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
The Mac won’t come on without the housing. You will need a magnet. The 2 LEDs that come on when pressing the button only verify that it’s plugged into a power source and getting 12V. Remove the bottom cover, then you will be able to access all diagnostic LEDs. Photo shows what kind of magnet will work and where to hold it to power the Mac on without the housing.
这个答案有帮助吗?
得分 2
1条评论:
you sure a magnet is needed to open it?
https://it.ifixit.com/Smontaggio/Mac+Pro...
完成的
添加一条评论
Perfect. Thanks! Best regards
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
olamife 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 1,106
