跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
Why is my battery draining quickly even after replacement?
Last weekend, my iPhone 5s got wet and the battery life started to suffer so I replaced it with a battery from Amazon. However, the battery is still draining fast. Is there something else that could be the problem such as a short in the phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
1) update the IOS if available
2) Remove all unwanted apps in your phone
3) back and reset the phone and boot as a new iphone and check whether issue reaming same if yes your Supposition can be right. run the correct diagnostic on logic board by apple certified technician
这个答案有帮助吗?
得分 0
添加一条评论
It's possible. Did you deal with the water damage or just replace the battery? If you only replaced the battery there are a lot of possibilities. Check you connectors and flex cables. Especially check if the battery connector is undamaged and debris free.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 216
