跳转到主内容
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 个问题 查看全部
问题已关闭
touch screen working weirdly after few (4-5)minutes of the usage.
The glass on left side of ipad raised over the body are millimeters (2mm). When I am using the ipad after 5min the touch on left side is working automatically eg:if I using browser it clicks links on left side,it opens left tabs automatically. If I'm on home screen it opens apps on left side.Everything stops if I lock and unlock the ipad and starts again after few minutes and if I play any video on device it starts odd behaviour immediately. Is replacing adhesive strips enough or should I replace the digitizer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sounds like a digitizer replacement not done properly. the ribbon could be pinched between the glass and aluminum chassis causing the issue. Best bet is just to replace the digitizer and make its done properly.
这个答案有帮助吗?
得分 1
1条评论:
I think that I myself applied pressure on that side, can I adjust it without replacing digitizer.
完成的
添加一条评论
Agree with Brian cable is most likely pinch between the frame
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 112
