跳转到主内容
The Iron Horse Warrior Race model is a 27-speed hard-tail mountain bike with a Aluminium (Alloy 6061) frame and 26" wheels. This model was released in 2005.
Why don't my brakes work?
No matter how hard I pull on the brakes, I can't stop
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
There are a few reasons your brakes may not be making contact with your tire.
First, double check that your brake cables are connected, this happens more often then you would think.
If you have traditional brakes your cables may just need to be adjusted (tightened if your brakes aren't touching the rim when you squeeze the handle), or, you might need new pads if they are worn out.
If you have hydraulic disk brakes you most likely need to add additional brake fluid.
You should always give your brakes a little test first thing when you jump on your bike!
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Its a metaphor for life.
Or just get new brake pads and/or make sure the cables aren't trashed
这个答案有帮助吗?
得分 2
添加一条评论
you need to tighten them. It's a pretty universal process. It can be fairly fiddly, having another person help you tighten it whilst you hold the pads just above the wire. another guess at this is that you may need new brake pads, they are consumable and can wear down. tightening them works until you need to buy new ones, it's basically re-calibrating them. The closer to the wheel they are, the more likely they are to stop it, so I recommend you look up a guide on google "How to tighten bicycle brakes" or how to calibrate them. I'm not a mechanic, but I have experienced this issue with my bicycle!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matt Halvorson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 1,054
