跳转到主内容
有关塑料主题的汇总。 包括修复技术,如去黄化,修复和改造。
9 个问题 查看全部
How do you take off paint scratches from a plastic surface?
I just wanted to ask how I would take off some white wall scratches off of my plastic vacuum ?
is there any type of liquid you can find at home that takes away that stuff?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
First you'll want to try one of the Citrus oil cleaners like: Goo Gone. Just test it out some where it won't show first. They do a good job on label adhesives as well. I would then try using a polishing powder like: Bon Ami with a damp cloth as it won't scratch. After either you do want to put on a protectant like: Armor All.
这个答案有帮助吗?
得分 5
1条评论:
thanks so much for the help I really appreciate it :)
完成的
添加一条评论
There are a variety of plastic cleaners, polishes, and compounds that work well for this. I have found Novus Plastic Polish Kit to work wonders; Meguiars has variety of products based on color and type of plastics; Mothers also has a polish for scratches.
这个答案有帮助吗?
得分 1
添加一条评论
First step is to remove the wall paint without Scratching the plastic surface. Dry wall paint gets soft with - water! No rocket science needed. If possible submerge it into water with a dash of dish cleaner for some minutes. Than take a wooden spatula or fingernails to scrub it from the surface. Any scratches you can polish with toothpaste or grease based polish like mentionned before.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
yataouss 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 72
总计 7,356
