跳转到主内容
捷威所制造的台式机的支持界面。 现在捷威被宏碁的子公司,现在捷威所有新的产品都是宏碁公司旗下的产品。
40 个问题 查看全部
Why is my front audio port not working properly
a few weeks ago the microphone port on the front of my gateway desktop top suddenly started malfunctioning so i plugged it in to the back of the computer to make sure it wasn't my headset it is one of the front aduio port.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The front audio failing could be caused by many different things.
Make sure that the volume control is not turned down or muted. Sometimes each port on the computer has its own set of volume controls.
Check the cable that runs from the front panel audio jack to the motherboard and see if it is completely connected. In am unfamiliar with your particular machine and where it should be connected.
Make sure that the jack is not loose. If it is, it has become unseated from the board that holds it in place and may need to be soldered back in place.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
D grover 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 340
