跳转到主内容
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Ipad mini not turning on and not being detected by itunes
After I did the screen replacement, the iPad wouldn't turn on, but since its happened to me before I know that i just had to disconnect the battery and reconnect it and would turn on, but it didn't. I then went to go check if iTunes would recognize the iPad,and it didn't recognized it. I've worked with ipad for over a year now, and this has never happened to me. I am for sure that no metal touched the mother board; i only use plastic when it comes to lifting up the cables. Is this fixable? What can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
I am having the exact same issue. the only difference is when I disconnect the lcd itunes will recognize the ipad. did you ever fix this issue?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ricardo Zapata 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 237
