跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
iMac Not Booting - Fan spins then stops - LED 2 blinks
Hello, my iMac appears to be having hardware issues. I thought it was a power supply issue, so I bought one from this website, but I'm getting the same issue. LED 1 lights up and stays lit, LED 2 blinks 1 time, LED 3 and 4 both do not light at all. Also, when LED 2 blinks both fans spin for about 3 seconds, then stop. This process never stops as long as the power cord is plugged in to the wall. Ive tried all the typical fixes, reseated RAM, reset SMC, pram, and replaced the power supply. I'm thinking it's the logic board, but I can't find anything online with these same symptoms. Any input would be much appreciated. Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
3条评论
Did what i wrote help you?
完成的
What ended up being the fault, mine does this problem also
完成的
I have a service check and they ask for 700$ to replace the motherboard. I throw away
完成的
添加一条评论
3个答案
最有帮助的答案
The first LED means your power supply is fine.
-it should always be on when the power is plug in.
The second LED means your logicboard is fine.
-it should aways be on when your computer is on.
The third LED means your video card is one.
If your second LED doesnt stay on that means you have a logicboard issue.
这个答案有帮助吗?
得分 3
添加一条评论
Just found the fault. Remove your ram vacuum and clean the slots, clean ram and fit 1 ram at a time, I removed the ram I upgraded 2 years ago now it boots up.
from my research if you still have issues it will be a logic board but check your ram first
这个答案有帮助吗?
得分 1
1条评论:
I had the same problem: upon opening the iMac, found LED #2 flashing about 1 Hz. Replacing the upgraded RAM with the apple original RAM allowed machine to boot. (Wish I had checked this BEFORE spending an hour removing the display and the adhesive tapes!)
完成的
添加一条评论
I had same issue and same led pattern. Like a dummy, I had LCD thermal sensor cable plugged into the unused port to the left instead of the port next to the Display data cable/LCD cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kelaure 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 2,209
