跳转到主内容
A Makita angle grinder released in June of 2010. Model number GA4030K.
4 个问题 查看全部
What is causing my angle grinder to make so much noise?
For the past several days I have been using my Makita GA4030 to work on an extensive project for many hours at a time. As I was using it this afternoon I noticed that the grinder started making a funny noise that it has never made before. What’s going on? Is this something worth fixing or should I just go buy a new one?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
When you dropped the angle grinder, you may have dislodged or broken some internal components. To find the problem, open up the angle grinder and look for damage and loose pieces. Damage could take the form of dents, unconnected wires, or loose graphite bits within the device.
The angle grinder is fixable - visit the ‘switch repair’ link on the troubleshooting page found here:
Makita GA4030K Troubleshooting
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nyssa Backes 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 20
总计 4,145
