跳转到主内容
The Olympus Stylus Tough 6020 combines advance imaging components with a rugged build so it can go along wherever your adventures may take you.
3 个问题 查看全部
My camera will not turn on, what do I do?
I keep trying to turn the camera on but it seems to be getting no power and I have not even gone underwater with it yet, so I know it is not due to water leakage. What do you recommend?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Please check and confirm the battery is fully charged and is seated properly withing the battery compartment.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem I turn it on unit makes a clicking noise and beeps then shuts itself down. Have a new battery fully charged.
这个答案有帮助吗?
得分 0
1条评论:
Same deal! Mine is at least ten years old and eventually started doing this a few years ago, even with a full battery. Wondering if it was a part that went bad over time due to extreme heat/cold or leaked while underwater as it has seen all of these conditions. I will dig into this and hopefully find an answer.
完成的
添加一条评论
添加你的答案
Taylor Carabin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 593
