跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
问题已关闭
Very bright screen after replacing screen
Hi I've just replaced the screen on my iPod touch 4th gen. I turn it on and it's very white but I can still see the apple logo. When using it again the screen is very white but can just about make out the icons. When I go into folders some parts of the screen overlay and it gets all confused, but it does all work software wise.
I'm not sure if this is the same as the white screen of death because I can see it (just about).
I've tried the following based on other pages on this site:
Resetting using the home and sleep button
Resetting using home/volume up/sleep button
Factory reset on iPod
Resetting whilst plugged into laptop/iTunes
Disconnecting then reconnecting the screen
Putting the sponge bit from old screen connector onto new connector
Checking light sensor for exposure (all intact)
Checked for pin damage on video connector and power connector (no damage seen)
I'm currently letting it drain to see if a dead battery might give it a more heavy reset. Only thing I haven't checked is if it's the screen itself but would have to send it back so wanted to hear other opinions first.
Any other solutions welcome as I've tried every trick and video I can find to solve this. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well it it is most likely that when they put your new screen on they pushed it on to hard and the screen is touching the pixels. I had my iphone repaired and there is big white spot. if you go to the place and ask to have your screen loosed they may do it. Hope this helped :)
这个答案有帮助吗?
得分 0
1条评论:
After thinking your ipod might be damaged
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 76
