跳转到主内容
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
137 个问题 查看全部
问题已关闭
Cannot fully open the laptop.
Hello everyone,
I have a HP DV7-6b30eb which is seriously overheating and i suspect the thermal paste needs replacing. The problem is i get stuck when opening the machine. I have removed all the screws on the bottom half of the machine and it looks like i have to remove the palm rest by lifting it up. It lifts up everywhere except at 2 points. In the zone of the R,4 and 5 keys and between the O,9 and 0. When i lift up the palm rest to the point where there is tension on these points i can see inside a bit and it looks like the points where it wont lift are see through plastic of some kind.I have tried moving it in every possible direction in the hope it would un-click, but no joy. I cant find a disassembly layout specific to my laptop on-line.
Please help! Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Solved it. Being a dumbass.
这个答案有帮助吗?
得分 1
1条评论:
Care to add how you solved it for others?
完成的
添加一条评论
As with a lot of laptops there is a hole on the bottom of the laptop where you have to push a screwdriver, or something alike, to push the keyboard out of its housing. Then you can remove 2 screws on the points i described having trouble with and then everything is a breeze from there.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 191
