跳转到主内容
加入维修社区 - 创建账户
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Replacement of screen assembly
Hi there,
I'm looking to replace the screen on my HTC One (M7 version).
I have read a couple of your guides, and I just want to confirm that I need something like this rather than something like this. Obviously, if I could do just fine with the cheaper product, I'll take that, but that's what I'm a bit uncertain of.
Thanks for your help!
Martin
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It depends on the problem you're display is experiencing. If the display is able to display a picture without any issues but does not respond to touch then you only need to replace the digitizer which is the cheaper part you listed.
If the display does not display an image or if the image is distorted or has issues then the LCD is faulty and you will want the whole display assembly (LCD/digitizer) which is the more expensive part you listed above.
Hope this answers your question.
这个答案有帮助吗?
得分 1
6条评论:
Hi BurnieG
Thank you very much for your response.
I should of course had described the problem with my phone. It's only the glass that's broken; the touch functionality and display features work just fine - also in the area of the cracked glass.
The reason why I did not mention this at first, I think, was because that this guide (HTC One Display Assembly Replacement) mentions that, "The touch screen and LCD display are fused together so it is very difficult to replace one piece or the other separately. In order to be successful, it is recommended to replace the entire assembly."
Looking forward to reading your advice.
完成的
Hey Martin you are correct about the display having the digitizer fused to the LCD. It can be a difficult task replacing just the digitizer on a fused display assembly. You run the risk of breaking the LCD if you are not careful when trying to remove the digitizer, especially if you do not have all the tools. If you have not done this type of repair and want the easiest repair then replace the whole display. If you like a challenge and want to attempt the digitizer only repair to save money or to gain some experience than I say it's worth a shot. You could try removing the digitizer before purchasing your new part. That way if you are succcessful you won't be spending much money and you have gained some experience. I am guessing you could find some digitizer only repairs for the m7 on YouTube. If you are in a hurry to get your phone fixed its quicker to replace the whole display. I hope this helps.
完成的
Thank you very much, BurnieG - and sorry for the late reply!
完成的
Your welcome Martin, and thanks for the reply. Good luck on the repair.
完成的
Hi again
I was just wondering, I can see that some of the sellers of screen assemblies on eBay and Amazon indicate that their products are OEM. Can you actually count on the product being from the original manufacturer? Most of the items indicated as OEM do have a higher price. Also, can you count on the item being of a higher quality, thus justifying the higher price?
Cheers
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Martin Christoffersen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 468
