跳转到主内容
Released April, 2014. CPU - Quad-core 2.3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M colors, 1080 x 1920 pixels, 5.2 inches. Internal memory - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
57 个问题 查看全部
Xperia Z2 Wont turn on
I recently replaced the LCD screen and after putting it back together it doesn't turn on when the battery is connected. When i disconnect the battery cable the screen lights up and the battery icon shows up. When i plug it back in the LED light flashes three times and nothing happens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
添加一条评论
8个答案
Is this whilst plugged into a power source? Was the battery disconnected before the repair?
这个答案有帮助吗?
得分 0
1条评论:
Yes...and yes
完成的
添加一条评论
Same problem. Didn't leave the battery connected when I did the job, no. Any solutions?
这个答案有帮助吗?
得分 0
1条评论:
Same Issue for me too, would be interested if anyone has a solution.
完成的
添加一条评论
Also having this problem. Was all working fine until I disconnected the battery to replace it. :/ Now it will look like it is charging with the red LED, but not actually turn on :/
这个答案有帮助吗?
得分 0
添加一条评论
anyone found solution for this?
这个答案有帮助吗?
得分 0
添加一条评论
replace the battery work 100%
这个答案有帮助吗?
得分 0
2条评论:
I just replace my battery as still not working..Dont waste your money
完成的
I have the same problem, i was thinking of a battery reseat
完成的
添加一条评论
I just replace my battery too. Not working. Dont waste your money. Buy new one.
这个答案有帮助吗?
得分 0
添加一条评论
http://forum.xda-developers.com/xperia-z...
这个答案有帮助吗?
得分 0
添加一条评论
The flex cable connector is not fully seated. It worked out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dylon Browne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 7,225
