跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
160 个问题 查看全部
Is there any chance to repair LED backlight (or replace)
Hello, i have Thunderbolt display with fault backlight - there is a picture if you point with flashlight on display and TB display is also in Display settings on my mac. If you are lucky, display turn on after power off and working for a while. Is there any chance of repairing backlight? Thank you. Milhaus
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
Sounds like you have a cold solder joint on the logic board on the WLED driver.
这个答案有帮助吗?
得分 3
10条评论:
Do you think you can post pictures of this? Im having the same issue but the display won't illuminate at all.
完成的
Jump to Step 12 in the IFIXIT guide: Apple Thunderbolt Display Teardown. It will show you the Supertex HV9982 3-channel switch-mode LED driver IC location.
完成的
Is there a good DIY way to take care of it? I'm trying to avoid unnecessary costs being a college student.
完成的
This is preaty advanced for a first timer.
Getting the needed tools will set you back a piece and you still need to locate the part. I would recommend you let someone with the skills & tools do this. I'd hate to see you make a mess of the display here which would be more expensive to replace.
完成的
Thanks Dan. The monitor did end up working for all of yesterday and I tried it today and the image stopped being illuminated. Do you have any ideas what it could be?
完成的
显示更多的5条评论
添加一条评论
添加你的答案
mfrybert 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 1,682
