跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 个问题 查看全部
its stuck talking a foreign language
My apple ipad2 it stuck in a foreign language I've tried several things please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What have you tried so far?
完成的
i need to change the launge on tablet
完成的
添加一条评论
4个答案
Tapping the "home" button three times in a quick sequence should turn it off. :)
这个答案有帮助吗?
得分 0
1条评论:
Hello but that is for quick access for the options you asked to turn on like assistive touch, voice over or invert colors but not language
完成的
添加一条评论
Hello you may have changed or someone changed your text language so this is what you will do: (P.S. I am using ios 8 so you might probably experience some difficulties if you are not using ios 8) First go to settings which looks like a gear, then press general which also looks like a gear and then in the 8th group last icon is saying language and then press it and the first icon will say ipad language, press that then change the language to english
这个答案有帮助吗?
得分 0
添加一条评论
Oh and yeah this might help you, language and region is just near the reset button
这个答案有帮助吗?
得分 0
添加一条评论
can u tell me how to change the launge
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
Barbara Beck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 969
