How do I fix the sound on my phone?
The media and all the ringers are all not working even though it says it isn't on silent. When I plug in the headphones, then it works and its the only way I can watch videos.
it seems to be your main speaker (Ringer) faulty. you may have to replace it
这个答案有帮助吗?
How do I do that ?
you can get an idea how to teardown it
did you ever figure it out???
I replaced my speaker and it still isn't working what can I do now
Backup all data and reset the phone. check whether speaker back to working condition, otherwise you have to check audio out/ amp section carefully
Turn Bluetooth on and off
这个答案有帮助吗?
Worked like a charm thanks bud
Was having same issue.. Came here for answers...saw a thread that said turn Bluetooth on and back off....worked for me...
Thank you I'll try that
Wirked like a charm wow
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 50
总计 199,939
23条评论
My speaker is not working how do I do it if u got urs to work...please... Thanks a bunch
由 floressusanne 完成的
I'm having the same problem. Did you ever get it fixed
由 Loka 完成的
I got the same problem
由 Tyliah Carter 完成的
I had to install an app called SoundAbout from playstore.
由 Walter Montgomery 完成的
When I make call people on other end can hear me but I can't hear them, volume is all the way up and when I get call it only vibrates
由 superdave446 完成的
显示更多的18条评论
