跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
297 个问题 查看全部
Thunderfly stuck in the middle of the screen ...
Hello,
Everything is said in the title, I have a thunderfly dead in the middle of my imac :(
Any tips ? Found some on Google but nothing really helpful ..
Thanks !
Update
FYI, it finally collapsed yesterday at the bottom of the screen ! :)
In the meantime, I had others flies crawling around and I just shutted down the iMac as soon as one go under the glass.
Regards,
Laurent
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I find it very funny that this is apparently a not-uncommon problem: http://forums.macnn.com/58/imac-emac-and...
However, here's what you need to do:
Use this guide to remove the glass panel on your screen.
Use some canned air to blow the little guy away, or if he's melted into place, you may need to very gently clean the LCD with a soft cloth.
That should take care of things for you. :)
这个答案有帮助吗?
得分 1
2条评论:
Hello Taylor and thank you a lot for this quick reply !
It's indeed fairly common as I already had the same issue with a Dell and a Sony monitor ... :-S
I used to live with it for those monitors but it's quite annoying for a shiny new iMac :)
I will check your solution but, if I see corretly, the bug is quite deep and below the cursor/pixels.
Laurent
完成的
Glad to help, be sure come back and tell us if it worked or not, and if it did, accept this answer. :) -Taylor
完成的
添加一条评论
添加你的答案
Tibus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 5,489
