跳转到主内容
The Blu Dash 5.0 Dual SIM D410 was released September 3 2013. Repairing this device is relatively complex and requires tools that have to be purchased.
70 个问题 查看全部
问题已关闭
Cracked my screen putting case on
Ok, so my friend when to work yesterday and took his phone out of his pocket and his case was half way off and he went to fix it and it slipped out! he called me later asking for my help on what to do since he has no electronic experience what so ever and i have replaced several screens already, so i did some research and couldn't find any screens or repair guides anywhere, the only thing i could find was a Digitizer and I'm not sure if you can use that or if i need to get the assembly?
can someone do a teardown or a repair and let me know? thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It is more difficult replacing the digitizer, but it can be done. You take the phone apart and disconnect everything, then you will need to pry the screen off as it had doublesided foam tape securing it. If you have a little scaple and something to help you pry it, it will take about 15 minutes. Slide the new connector for the digitizer into the chassis, re-tape it, then hook everything back up, put the back part of the chassis back on, screw in place and there you go.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 134
