跳转到主内容
Sony’s 18.2 megapixel camera meant for general photo taking, 3D images, and filming. Model number: DSC-WX100.
7 个问题 查看全部
What might be causing the screen to be dim?
The screen, even after the camera has indicated to be fully charged, is dimly lit. This is despite have the screen brightness at the highest setting. An image is still visible, but glare is an issue in both natural and artificial light.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The first thing you should try in this case is to check the LCD screen brightness settings on the camera. If the brightness setting is too low then the LCD screen will appear dim. Go into your camera settings to change the backlight brightness. Another case is that the backlight bulb is dead, thus you'll need to go disassemble the camera to first get to the bulb, and then replace it. Other details for this issue can be found on our troubleshooting page.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Peter Prins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 1,849
