跳转到主内容
How do I replace my track pad button?
Mouse pad Button is stuck and I need a replacement, donor or otherwise. Please advise.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
A less expensive answer if you want to go that way would be to simply use an external USB mouse. If the button is stuck in the on position you may need to disconnect the trackpad cable to operate properly. Ralph
这个答案有帮助吗?
得分 2
添加一条评论
I am using a new answer because I can't leave a URL in comment.
If you do want to replace the upper case here is a source. Ralph
http://cgi.ebay.com/Apple-PowerBook-G4-1...
这个答案有帮助吗?
得分 2
2条评论:
For the record I tried three times to leave this as a comment but the program would not allow me to leave a "clickable" url. Ralph
完成的
So it isn't just me! If it happens to everyone I'll mention it on the uservoice
完成的
添加一条评论
You would need to replace the upper case.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jackson Carrie 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 6
总计 3,196
