跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Boot Loop and won't turn on if battery is plugged
i got an iPhone 4s which stucks on boot loop after software update to 8.3.
I plugged in a new Battery but it will not boot.
But if i unplug the battery and leave the cable plugged in, it boots in bootloop.
Anybody here, who got the same or similiar issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I think you have a corrupted install and you need to repair your firmware.
So if I were you, I'd put the old battery back and restore the phone.
The easy way, try it first:
- Download and install the latest version of iTunes on your laptop (new version just out now);
- Turn off your iPhone;
- Press and hold Home Button;
- While pressing Home Button, connect your iPhone to your computer using a known good sync/charge cable;
- Your phone should turn ON and show you "connect to iTunes," while iTunes will tell you that it "detected an iPhone in restore mode;"
- You will be prompted to download and restore your firmware. Accept and leave your iPhone undisturbed until the process is over and your iPhone starts fresh.
NOTES:
- If you iPhone's Wi-Fi was not working properly before the initial update to 8.3 that caused this issue, then there is a high probability that the new restore will fail as well and your phone will remain stuck on restore. Let us know of that's the case; there could be a remedy;
- All your data will be erased, hope you have a back-up somewhere;
- You'll need your Apple ID and password to unlock your iPhone, if activation lock was ON (Find My iPhone ON) before the restore.
这个答案有帮助吗?
得分 1
9条评论:
I have changed the dock connector against a new one.
The phone was complete dead but itunes recognized it in dfu mode.
The software installation process worked fine with itunes but the phone was still dead, black screen.Then i took the new battery of and placed the old one in.The update process finished and the phone starts, but the phone did not recognize my sim card. Also, the phone won'T do an restart. So, i have done an hard reset. Now, the phone vibrates but it does not goes on
完成的
It just vibrates again and again, the screen is off
完成的
There is no problem with wifi.
完成的
I have tried the same thing as i told, the update process on itunes finishs but now, it won't turn on, even with the old battery. But my mac recognizes that the phone is plugged in.
完成的
This is very strange. With another display, it works turns on.
But i don not think that the old display is defectiv cause it works an hour ago
完成的
显示更多的4条评论
添加一条评论
添加你的答案
christian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 338
