跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 个问题 查看全部
LED Backlight Dead. PSU replacement or Complete Screen Replace?
My backlight just died on my iMac, opened it up and there is is an Electrical burning smell.
I can see Mac Booting up if I use a torch - so guessing its the LED driver board is fried or potentially something in the PSU.
Question 1.
Could this just be the main PSU - does it have a separate feed for the LED Backlight ?
Question 2.
If not the PSU Is there a way to just replace only the faulty board or would I need to replace the whole LCD Panel ?
This happened just 3 months out of warranty arragh !!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Turns out it was a Capacitor on the Logic Board that was at fault and thankfully not the whole screen. Capacitor is being replaced
这个答案有帮助吗?
得分 2
2条评论:
Hello. I had the same problem as you.
as it solved?
you can tell me condenser was? thanks and regards
完成的
I don’t understand the previous comment.
“as it solved?” -> Is it solved?
“you can tell me condenser was?” ->
Can you tell me what capacitor it was?
Anyhow, I have the same questions.
完成的
添加一条评论
添加你的答案
Steve Francesco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 409
