跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Jammed Power Button + Broken Vibration
This is a very helpful site for the tear downs and other basic needs. But my iPhone (which has no warranty for the stupidity that is me) has a jammed power button, and my vibrator for rings is very "fart" noisy. I don't have the money to get a new phone or do a trade. So I was hoping someone could tell how to do it myself!
How do i fix a jammed power button and a bad vibrator?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
6个答案
已选择的解决方案
Replacing the vibrator shouldn't be too difficult at all, you can follow this guide to open your phone, and we've got cheap iPhone 3G vibrators available here.
While you have your phone open, you should be able to easily reseat the power button as well. Hope this helps!
这个答案有帮助吗?
得分 2
添加一条评论
the chager part of the iphone doesnt want to work or chage the phone what could i do?
这个答案有帮助吗?
得分 0
1条评论:
vpne, asking this in a new question will help to get other responses. :) In your new question, could you clarify what you mean? Does the charger connect completely, did you try using a different charger, etc?
完成的
添加一条评论
spray compressed ait into the charging port and clean out lint with a toothpic.
这个答案有帮助吗?
得分 0
添加一条评论
I just shoved a piece of black tape inbetween the viberator and the metal case that hold the viberator in and it works like new:)
这个答案有帮助吗?
得分 0
添加一条评论
3g is an easy device to fix! Because u can always take it appart. What i suggest though is that u go to ebay , because here they dont sell this thing, and look for iphone 3g housing assembly, it cost sabout $40 but u get practically a new phone! U just put ur old motherboard into the new housing and cover it with the screen... It will fix Im sure all problems jammed buttons vibrators, and even the battery..
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
my iphone button got stuck at top and try open it lose the voulume button and top plz help me thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wendy Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 8
总计 18,863
