跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Camera flash not working
My Iphone 5s Camera flash doesnt work, its supposed to have two leds, the yellow and the white, the white doesnt work so i press the flashlight icon in control center and it gets highlighted as working but nothing happens, when i switch to video mode it doesnt light up, i notice the LED or bulb doesnt work because when I take a picture with flash ON the yellow light flashes but theres no flash on pictures, so Its not a software problem, please tell me how to fix this problem and the replacement i need to buy, thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
3条评论
my device camera as well as flash not working . I there any way to fix it
完成的
it supposed to be yellow and white flash but my iphone 5s flash is just white which still works
完成的
My flash went out as well how can I solve this problem
完成的
添加一条评论
6个答案
已选择的解决方案
You need to buy a power volume flex as the led light is located on that
这个答案有帮助吗?
得分 3
1条评论:
This was the solution to my problem thank you very much!
完成的
添加一条评论
I am also facing this Problem. My volume down button is also not working.. First the volume button fails then Flash of the camera. Amber led working but white one is not!!
这个答案有帮助吗?
得分 1
5条评论:
Its the power volume flex, that is involved in volume has the led from flash lock button etc, this piece is cheap and replaced in 15 min!! Good luck!!
完成的
was it safe? I mean repairing? cause I am afraid that something other will not mess up
完成的
Well, this piece involves a lot of the phones features but just follow the video and i guess you'll be fine, but if youre not the the "i'll repair it myself person look for someone to fix it for you, obviously experienced.
完成的
can u post a video?
完成的
Sania nadeem,
Finally I fixed this problem to replace the (power volume and flash light) single flex...
完成的
添加一条评论
Here you can get a power volume flex http://www.iboxfix.com/flex-ribbon-c-164...
这个答案有帮助吗?
得分 0
添加一条评论
same to sania
这个答案有帮助吗?
得分 0
添加一条评论
my iphone 6 flashlight is working on Video and flashlight but When I taking a picture with flash, white led is working but Amber led is not working.. because of that picture with flash is being dark !
Do you have any idea What is the solution ?
thank you
这个答案有帮助吗?
得分 0
添加一条评论
i;gt9 6tp/y8 g;p.gilbuj,gbulihilihh
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 20
总计 24,676
