Is there any Sata to mSata adapter?
Hi,
does anyone know where to get an adapter cable - from Sata to mSata?
So that i can connect any normal sata SSD to the internal mSata port?
There is no room to support an adapter. Besides, the port on the logic board for the SSD is PCIe and a custom ribbon connector.
If you are talking about the HD port that is a standard 2.5" SATA connector and the 2nd drive kit used in the older models will allow you to put in a second drive (HD or SSD) in a SSD only model.
这个答案有帮助吗?
i understand, but in general is there any adapter for it which i could use?
No internal adapter - Externally you could use the IFIXIT Universal adapter but that allows you to connect either a SATA or mSATA drive to the USB port of the system.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 380
