跳转到主内容
The Nikon Coolpix S8200 has a 14X optical lens, a monitor that is 7.5 inches wide, and weighs approximately 7.6 oz.
8 个问题 查看全部
Keep getting "lens error" message
With my Coolpix S8200 camera, I keep getting "lens error" on my screen. I have turned my camera off and on multiple times and replaced the battery with a new one but nothing seems to be helping. Is there anything I could do to try and get this camera working again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
If you have already tried restarting the camera as well as replacing the battery, then the next step in the process would be trying to replace the lens of the camera. You should be able to follow the steps for this process on ifixit. If there is not a guide on how to replace this part or if this solution also fails, then the next step would most likely be replacing the camera itself. Hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ashley Wilbur 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 850
