跳转到主内容
Help with reassembling nano 4th gen
I have successfully fixed a broken clickwheel cable, but am having problems regluing the clickwheel plate to the case. What is an alternative glue? The ribbon cable from the clickwheel won't readily fit back inside the case once reconnected to its white socket. The cable won't push any further into the base of the iPod. I don't want to push too hard in case it breaks. Finally, can the hold switch cable (which was broken) also be replaced? It seems to go to the main PCB without a plug?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
on the two nanos i disassembled, i simply didn't use any new "glue" - but if i had to - i would use adhesive strips licke the ones for the iPod touch/iPhone.
i know it's tricky - but you can get it together that it would fit - but since you broke the hold switch - i would try to fix that first.
i didn't find any hold switch cables on ebay - so i hope that the original one isn't to damaged.
the cable is soldered on the logicboard - no connectors needed
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jules 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,283
