跳转到主内容
A business-class desktop PC, sold in multiple form factors and configurations.
17 个问题 查看全部
when I press the power button nothing happens.
There is an led on the MB indicating that it has power but when i press the power button nothing happens. All the cables are connected and there is no visible damage to the motherboard and other components.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
6个答案
I would check power cord first...then check the power connection
这个答案有帮助吗?
得分 0
添加一条评论
Hi guys, I have the exact same problems. I have checked the psu and power connectors, and the front card power button, they are all fine. The bios chip gets really hot though.
What can I do?
thanks
这个答案有帮助吗?
得分 0
1条评论:
my guess would be electrolytic capacitors in the power supply are going bad
purchase another similar P.C - put your hdd & ram in it - doesnt cost much
完成的
添加一条评论
Replace the motherboard. It'very easy. While doing that add 3.8 processors and AMD 5450 video board. Put all 4 gigs of memory. Add 1 terabyte hard drive. Install Windows 10 and you,'ll have a nice running computer. But the motherboard alone will solve your problem, You can get them cheap on EBay.
这个答案有帮助吗?
得分 0
添加一条评论
I’ve had the same problem and I have a answer for it. There should be a green pin inside and if it’s on the “RTCRST” pin move it to the “PSWC” pin and that will work.
这个答案有帮助吗?
得分 0
添加一条评论
Brother this is problem of your front Power panel card unplug the front button power card and on PC directly or replace front card of power!
这个答案有帮助吗?
得分 -1
添加一条评论
check processor chips
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Joran Geeraerts 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 1,816
