跳转到主内容
各种形状、大小和颜色的安卓手机的维修指南和拆卸信息。获取DIY修理手机所需的一切。
How to replace the screen on a Yota YotaPhone 2?
Salve a tutti......ho appena comprato lo smartphone "Yotaphone 2" ma a seguito di una caduta si è rotto il vetro del display anteriore.... Sapete chi lo può riparare?
Grazie
Mario
Google Translation
front display repair broken
Hi everyone ...... I just bought the smartphone "Yotaphone 2" but after a fall broke the glass of the front display .... You know who can fix?
Thank You
Mario
回答此问题 我也有这个问题
这是一个好问题吗?
得分 15
5条评论
Yota real bad glass plz make spare available soon. INDIA
完成的
i want back screen of yotaphone C9660, please advise from where i can get it in india.
完成的
I have broken my yota phone 2 e ink display glass .where in India can I get it replaced
完成的
I broke my display in yotaphone , where i can repair in romenia?
完成的
i dropped my phone and the front glass broke, although the display is functional. can anyone suggest me the replacement schemes available?
完成的
添加一条评论
11个答案
最有帮助的答案
my screen is ceacked pls send me your service center in gujrat india
这个答案有帮助吗?
得分 1
添加一条评论
You can try Fixez.com :)
这个答案有帮助吗?
得分 0
添加一条评论
Anche io ho lo stesso problema. Hai risolto?
这个答案有帮助吗?
得分 0
添加一条评论
Purtroppo no....ho venduto il telefono come rotto
这个答案有帮助吗?
得分 0
添加一条评论
hey. i bought a yotaphone1 it felt on a screen and now only the reading side works.
can you help me
这个答案有帮助吗?
得分 0
1条评论:
Did you find how repair it ?
完成的
添加一条评论
Yes, there are shops that can repair the front, and it is expensive. Got my repaired for a half of the cost of the phone. While on vacation, I dropped it again and broke it in the same location. So, again repair is required. I will not do the repair until Yahophone comes up with some type of protective results. I am now in process of looking for another brand. Sorry!!!
这个答案有帮助吗?
得分 0
2条评论:
Buy another phone for back-up!!!!
完成的
Just tried to buy a screen from an Indian company for around US$90. They will not sell to overseas buyers!?!?
It's easy enough to change out the screen but to have the phone repaired by a Yotaphone agency costs approx US$290!! That is a ripoff!!
What the heck is going on!? The phone is defective in quite a number of ways. The hotspot does not work. Telstra say the problem is with the phone. Connection to the car's hands free using Bluetooth is unreliable. Since the automatic upgrade from 4.3.3 to Android 5.0 the phone is hot and exhausts the battery within 3/4 of a day. Finally, the glass is close to the edge of the phone such the slightest knock on the soft frame results in the glass shattering.
The Yotaphone website is no help.
It's an aesthetically beautiful phone but the spt is just awful and for that the mgmt of Yotaphone has to be blamed.
I strongly advise anyone now not to buy this phone unless they just want to frame it and put it up on the wall to look at.
完成的
添加一条评论
If anyone is still looking for a place to get your Yotaphone 2 repaired, this is the info that Yota Devices provided me, the front glass of my phone also broke.
You can contact either the UK service centre:
Premiere Eurocom
Unit 412/413 Centennial Park, Centennial Avenue
Elstree, Borehamwood - WD6 3TN
United Kingdom
WebSite - http://www.premeuro.com/RepairForm.aspx
Phone +44 20 89538478
Or the one in Germany:
dat repair
Ingram Micro Services GmbH
Am Sophienhof 8-10
Flensburg - 24941
Germany
http://www.datrepair.de/
info@datrepair.de
+49 461-95775-0
这个答案有帮助吗?
得分 0
1条评论:
Premiere Eurocom won't repair anymore. They said yotaphone wasn't giving them a supply of spares anymore.
完成的
添加一条评论
I've just had my Yotaphone 2 exit my breast pocket and land inconveniently on its edge on a cement floor. The glass has shattered extensively. Before this, I had installed gorilla glass on the screen but that did not prevent this unfortunate breakage. A quote from T-Dimension to replace the screen is $330 Australian. I think I will wait until prices come down and there is an effective urethane surround so that, should this happen again, my phone will stand a better chance of surviving the experience!!
这个答案有帮助吗?
得分 0
添加一条评论
Buona sera, stesso problema anche per me. Telefono caduto e schermo scheggiato, ma per fortuna solo quello anteriore e non il posteriore in e-ink. Ci sono dei tutorials per il teardown in giro per la rete, ma non ancora qui su iFixit.
Qualcuno potrebbe condividere il nome di un fornitore di parti di ricambio per lo YotaPhone 2? Un distributore online ne ha venduti molti in Italia negli ultimi mesi e ci sarà da aspettarsi che il numero di telefoni da riparare crescerà.
Ciao
Massimo
这个答案有帮助吗?
得分 0
添加一条评论
YotaPhone 2 in questo caso è uno smartphone di fascia qualità prezzo molto buono, ma con questo fatto purtroppo che adesso costo è di circa 130,00€ su principali marketplace in europa, riparare un dispositivo con display rotto (diciamo vetro crepato) è poco conveniente.
Per adesso l'unica fonte sono le assistenze autorizzate in collaborazione con casa madre, dove eventuale intervento di riparazione spesso richiede cifre alte, dove in fondo cliente decide di rimettere 20,00€ 30,00€ in più, acquistando un'altro prodotto (magari stesso modello) nuovo.
Soluzione come staccare solo vetro, e assembare uno nuovo sono più convenienti se fai da te, oppure trovi un negozio/centro assistenza di zona che potrebbe offrire soluzione con meno spese.
In questo modo soluzioni per riparare vetro crepato sono due:
Effettuando laminazione completa usando piastra OCA che sara più precisa e meno complicata, richiede disponibilità di macchinari professionali come laminatore OCA (macchina sottovuoto) oppure,
uttilizzo di UV colla LOCA, ( più ecconomica) che richiede più tempo e una buona mano d'opera.
Se invece da sostituire avete anche display, va considerato ricambio completo già assemblato in fabrica.
In questo caso prezzo di ricambio sicuramente è più alto.
Un display AMOLED in generale sono costosi solo per fabricazione, quindi anche prezzo d'acquisto sarà sicuramente più alto rispetto un display standard come TFT al esempio.
Insomma, dovete valutare Voi stessi, quanto vi conviene riparare vostro dispositivo, che per adesso dispobinilità di ricambi è ancora limitata, magari con tempo ci saranno disponibili in vendita ricambi a prezzi accettabili.
Potete verificare costo di intervento chiamando centri assistenza chiedendo un prevetivo, Io lo fatto per curiosità e sono rimasto senza parole, fatelo alche Voi, e scrivete sotto dove avete chiamato, e quando vi hanno chiesto, cosi facciamoci due risate insieme.
Centri assistenza autorizzata Yotaphone
这个答案有帮助吗?
得分 0
5条评论:
Grazie per la risposta. Nel caso in cui si volesse applicare una colla LOCA, occorre prima rimuovere i frammenti di vetro rotto? Detto altrimenti, questa colla deve essere applicata sullo LCD nudo?
Thank you for your note. Is the LOCA glue applied on a naked LCD screen or can I apply it on top of a broken glass? The result of the latter approach may be inesthetic.
Massimo P.
完成的
Si, Vetro crepato deve essere rimosso. Bisogna essere molto attenti nella fase di separazione per non danneggiare pannello lcd.
un esempio da youtube portebbe dare un esempio di processo di questo metodo
Dopo bisogna pulire lo schermo con alcool isopropilico e rimuovere la vecchia colla.
Attenzione anche a la parte posteriore dello schermo, non deve essere bagnata, consigio di coprirla in fase di assemblaggio con colla liquida LOCA.
Un esempio:
https://www.youtube.com/watch?v=fsJZnoGR...
完成的
Una verifica per esserne certi: su uno YotaPhone 2 lo schermo in vetro è incollato sullo schermo LCD? Non sempre è così su altri telefoni,
Just be sure I am understanding correctly: on a YotaPhone 2 phone is the front glass glued on to the LCD screen? This may be not the case on some other phones.
Grazie, M
完成的
Display frontale:
Da 5” pollici AMOLED con risoluzione Full HD pari a 1920×1080 pixel e 442 ppi
Tipo di vetro: Corning Gorilla Glass 3
Display posteriore:
Schermo e-ink/e-paper da 4,7” pollici con scala di grigi a 16 livelli, risoluzione 960×540 pixel e 235ppi
Tipo di vetro: Sempre Gorilla Glass 3
Vetro è lo schermo sono assembati con FOGLIO ADESIVO COLLA OCA 250µm
Ruolo di vetro è soltanto protezione dello schermo.
P.s. Scrivi pure in Italiano ;)
完成的
Grazie :-)
Quindi quando si acquista il Corning Gorilla Glass 3 bisogna procurarsi anche il foglio di colla OCA da 250µm (sagomato!), il che rende le cose più complesse, visto che è difficile reperire il vetro. In sostituzione si può acquistare la colla semi-liquida e stendere uno strato sottile tra LCD e Gorilla glass. In questo secondo caso occorre una lampada UV?
完成的
添加一条评论
i see that the screens are available on ali express. and the instructions on how to repair are on youtube. however, i do not think i could manage to make the repair myself. someone with some experience might fare better.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mario 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 54
总计 12,425
