跳转到主内容
加入维修社区 - 创建账户
Panasonic 于 2004 年 1 月 1 日发布了 CF-29。它的设计初衷是让美国武装部队、服务人员和爱好者能够在最恶劣的环境中使用。Black Hawk CF-29 于 2009 年发布。
How do I remove bios password
I need to remove bios password
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 14
添加一条评论
4个答案
已选择的解决方案
1) Locate and remove the RTC battery
2) locate and remove the main battery and unplug power supply.
3) depress the power button for 30-60 seconds.
you do not have to solder anything to the board if there are posts ic 61,63 on MAIN PCB then just put a jumper across them while you power up. if its just 2 SMD pads just use a needle probe to arc the connection.
这个答案有帮助吗?
得分 4
添加一条评论
最有帮助的答案
remove cmos battery for about 10 seconds.
这个答案有帮助吗?
得分 4
7条评论:
for a better result remove the battery for about 5 minutes, because sometimes it needs more time :)
由完成的
don't forget to hold the power button down for 60 seconds and remove the main battery as well.
由完成的
Remove the BIOS battery for more than two hours and the problem still exists..
由完成的
Removed the cmos battery, removed the main battery, left it for about 18 hours. No results. I pulled the batteries and shorted the pins while holding the power switch for 60 seconds. Still didn't help at all. Then I tried every combination of shorting, unplugging, and turning on that I could think of. Still have the problem....
由完成的
does the the problem above has been resolved??
由完成的
显示更多的2条评论
添加一条评论
I find this article about how to reset or remove BIOS password, perhaps it will help you solve your problem:
http://www.recoverlostpassword.com/artic...
这个答案有帮助吗?
得分 2
添加一条评论
I tried the "remove all power" tricks mentioned above (also mentioned in many places on the Internet), and they did not work for my CF-29 Mk3 (Model CF-29HTM50BM). What did work for me was upgrading the Embedded Controller and BIOS firmware from a pair of diskettes as mentioned in this thread from Victor at AllService (https://www.allservice.ro/forum/viewtopi...). Download the files CF29-EC.rar and CF29-BIOS.rar from the links in the thread, create the pair of bootable diskettes, upgrade the EC firmware first, then the BIOS firmware -- at this point my BIOS password was removed. I went into the BIOS settings and disabled the password at boot.
Now, will this same procedure work for you? Maybe -- my EC and BIOS were downlevel, so the bootable diskettes did have to perform an upgrade, maybe that's required.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tom elliston 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 82
总计 55,623
