跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Why can't I hear anything after reassembling my phone?
Yesterday my iPhone back to life after being spilled with water. I found here the way to open and dry it and it finally turned on. Everthing was working well until I was called, and I couldn't hear anything, nevertheless, who called me was able to hear me. Do you know which is the cable that I may not assembled well?. I tested the camera, and it isn't working either. This was my first time opening and fixing (or trying to fix) my iPhone, so please, don't laugh at me :-D
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
What iPhone generation do you have ?
the 4 generations are all different and it would be great if you could provide that info - it simply makes it easier (not to write everything for 4 different models ;-) )
完成的
I have a 3G 16GB :-D. Thank you!
完成的
添加一条评论
2个答案
已选择的解决方案
thanks for the info.
disassemble it again and check ribbon number 3 - thats the one for the earpiece.
you can use the logic board guide - but stop when you reach the connectors ;-)
这个答案有帮助吗?
得分 3
10条评论:
I think I have an issue there, the little tab where the ribbon cable 3 is connected does not keep it fix. Not the white part, but the dark one is a little loose :-S
完成的
does the cable move freely when the tab is closed? if the cable stays in place - but the tab won't - maybe you could fixate it with a little piece of scotch tape? - in theory - this should prevent the tab from moving around and that way the earpiece should work (as i wrote - in theory ;-) )
完成的
I tried with the scotch tape, but it still not working :-(
完成的
too bad, can you see why the tab won't keep the cable in place ?
完成的
I think the little black tab is damaged because I looked very close at it in looks like being separated from the logic board, for a tiny space but I think that could be the issue :-(
完成的
显示更多的5条评论
添加一条评论
I Have exactly the same problem, i change my battery but when i assemble it i cant hear i try to reassemble a lot of times but i have the same problem :(
这个答案有帮助吗?
得分 0
3条评论:
if you don't hear anything - does cable 3 fit well or is it loose?
完成的
It moves even when I close the tab, so, I'll try what Markus suggested, I think it could work. If I have success I'll let you know :-)
完成的
me too cable 3 is trickyyyy ,
完成的
添加一条评论
添加你的答案
Geraldine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,668
