跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
Batteria sostitutiva migliore MacBook 6.1- Best replacement battery
Ciao a tutti,
Vorrei sostituire la batteria del mio macbook 6.1 unibody Late 2009 ma son indeciso su quale batteria prendere per sostiuirla?
Avete Consigli? Grazie mille
Hello everyone,
I would like to replace the battery in my MacBook unibody 6.1 Late in 2009 but are undecided on which battery to replace it with?
Do You Have Any Recommendations? Thanks a lot!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
I would replace it with this battery from iFixit's website: MacBook 13" Unibody (A1342 Late 2009-Mid 2010) Battery
You can also use this repair guide to help you along the way: MacBook 一体机身 A1342电池更换
In my experience, it is fairly simple to replace the battery in this specific MacBook. Actually, I replaced this same battery for the same computer roughly a month ago and did it in under 30 minutes.
Hope this helps and good luck.
MacBook 13" Unibody (A1342 Late 2009-Mid 2010) Battery图片
产品
$79.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paolo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 907
