跳转到主内容
Will the 2010 MBPro Screen fit a 2011 MacBook?
I need to replace the display on my Late-2011 macbook, and both time and money are at a premium. I've found an affordable example which will arrive in good time but it's from the 2010 model MacBook, and mine's the late 2011.
Will this screen fit, and work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I got around this problem by taking the glass from the 2010 keeping the 2011 assembly painful long process but works .
完成的
添加一条评论
1个答案
已选择的解决方案
LCD, yes.
Full assembly, no.
2008 A1278 model uses an LCD assembly with the sleep magnet on the other side than the 2009/2010/2011.
2009 assembly and 2010 assembly are same thing, but wifi wire is 1 or 2mm shorter on one vs. the other.
2011/2012 assembly use different webcam, different webcam cable. Also these do not have wifi card in the lid, and they use a different wifi antenna which will not fit in the clutch cover.
So LCD, yes. Glass, yes. Entire ASSEMBLY, no.
这个答案有帮助吗?
得分 6
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 15
总计 3,233
