跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
问题已关闭
My just bought Samsung galaxy s5 battery drain quickly
I have purchased a Samsung Galaxy S5 from the store. I open it and I begin by charging it for the first time, but without turning it on. The battery was 61%, so I waited until 100%. After that, I turned on the phone and proceeded to set it up. The version of Android was 5.0 Lollipop (I don't know how this is possible as I thought I need to update it myself from 4.4.2 to 5.0).
While I was entering in the information for the first time, the battery suddenly fell from 100% to 95% in just 5 to 10 minutes, during the first steps where I had to create a Google account and set up my phone options.
I heard rumors that 5.0 Lollipop drains the battery quickly so I downgraded to 4.4.2 KitKat with the hope that it'll fix the battery problem. I downgraded successfully without error.
I have the same problem—the interesting thing is that I didn't download more than 5 apps. I only have Skype, Facebook, Messenger, WhatsApp, Viber and Instagram. All the other apps are from the phone itself.
Whenever I go to WhatsApp to check messages or chat (or anywhere else), the battery falls 1% after 3 minutes. All of the NFC options, location options and other unnecessary options are turned off. The brightness is also on low. In 15 minutes of use I notice that the battery falls from 80% to 65% or 60%.
I have already done a factory reset twice, while I was downgrading to KitKat 4.4.2.
I'm a new user of a Samsung Galaxy S5. Is this normal or abnormal? What is the problem and how can I resolve it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello,
The first thing to always try is adjusting the brightness. If after you test that and there is still a problem, navigate to your settings and play around with usage settings such as when data is refreshed or how apps run in the background when not in use. In my experience, Lollipop is not the culprit of a poor battery.
Good Luck!
-John
这个答案有帮助吗?
得分 0
1条评论:
I'll upload some photos and you'll see that i use only 5 apps the simple...
完成的
添加一条评论
i have the same problem.buyed brand new galaxy s5 plus and on idle for 4,5 hours i get 90% from 100 %.i have lollipop 5.0.2 stock.i'm very nervous because i payed almost 400 euros for it in mediamarkt and i can't use it even for a day? i think better buy an iphone
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,712
