This is a belated answer so hopefully it can be of use to folks who search for and find this question.
I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, front camera, rear camera and home button extension flex (see this guide). Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
If you have access to a multimeter, you could measure the battery first. If it reads ~3.8V - 4.2V, then it is good. Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the Home button flex first, then add the rear camera, LCD & Digitizer then from camera flex.
If the bare-bones setup does not get recognized by iTunes, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair.
5条评论
Might have missed a connection or didn't plug a connector in the whole way possibly? I would re-open the iPhone and recheck your connections.
由 dancheripka 完成的
Just checked, all connectors are plugged in! :(
由 iKatia 完成的
Try holding down the wake/sleep button and home button down at the same time till you see the apple logo.
由 dancheripka 完成的
If that don't work try connecting it to iTunes and try that same process.
由 dancheripka 完成的
It's not recognised by iTunes, I had no luck..
由 iKatia 完成的
