跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 个问题 查看全部
Changed wifi airport adapter - hardware not installed
Hi,
My macbook was working fine until i dropped water at him.
I dried all computer and turned on. Everything were working well, except the wifi that are showing the message: "No hardware Installed."
I tought weird, because bluetooth was still working, but wifi doesn't.
Even that, i bought an airport adapter and installed. But the message still there: "No hardware installed".
What could be the problem? What can i do to solve that?
Best regards!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
If you got a new Airport card and still are having issues, the connector on the motherboard may have been damaged. I would check the 'About the Mac' window and look at the system report to see if the system detects an airport card. If not, you could try an OS X restore. Otherwise, this issue is hard to fix...
这个答案有帮助吗?
得分 1
2条评论:
Hello Jake,
I've tried many ways to fix, but the solution was clean the contact of airport and re-install it. That works fine. Thank you for your answer.
完成的
Glad to hear it it working again. I would've never thought to clean the contacts.
完成的
添加一条评论
添加你的答案
Rafael Poli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 247
