跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
Adhesive for the glass on the screen
Hi, I had to replace the glass cover as the old one had cracked.
The only problem is that the new perspex/glass cover had only double sided sticky tape on it to hold it onto the metal behind it and is coming off every time I open/close my mac even after removing the old glue from the metal section
I was wondering if there is any sort of adhesive strips I could get to attach it properly or even double sided sticky foam but what thickness would you recommend..
I've searched online and I can't find any strips to buy locally (I live in the UK) so I would be happy using the foam but I'm unsure as to the thickness.. :S
Many thanks!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Before buying another kind of tape try heating up the glass and with a cloth (so you don't burn your fingers) go around pushing it agains the frame. Don't heat it too much so you don't melt the rubber gasket
这个答案有帮助吗?
得分 1
添加一条评论
I use Red tape for repairs like this. Found on eBay just search for "red repair tape" 8 or 10mm should work for you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kcnbob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 955
