跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
问题已关闭
Why is my iPhone shutting down at 30%?
I just replaced the battery and the phone is now shutting down at 30%. I tried to run it down further by charging it enough to get started and then running video and can't get it down further. (Tried at least 10 times in a row.)
I also see that this battery only reports a full charge capacity of 1336 instead of 1430 using iBackupBot. It makes me wonder if this battery is defective. I actually have 2 iPhone 4s' and replaced both batteries (from ifixit). The other reports a full charge capacity of 1400 and works fine.
So, is this a bad battery?
tia.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try the old battery and see if it's foing the same
Most likely it's a faulty battery
这个答案有帮助吗?
得分 1
1条评论:
Yes. I believe it is. I contacted iFixit and they are sending me a replacement.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 141
