跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Hot glue antenna into place?
Hi,
Hoping someone can offer me some advice.
Recently, my wifes iPhone started having wifi and GPS reception issues. After trying a number of software type solutions, I (correctly) guessed that it was likely due to a loose antenna connector.
Following the great disassembly guide here, I managed to take apart, reconnect the antenna and reassemble the iPhone. All was working great however at the time I did notice the 'snap on' type connector wasnt particularly sturdy and would be likely to disconnect again.
Lo and behold, it has disconnected again. This time I'm resolving to take apart, snap back in place and then apply a small amount of hot glue to keep it there.... does anyone see an issue in doing this/anyone had success doing this?
Cheers in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The hot glue i know is totally unproblematic(i'm from germany - so i know only the stuff we have).
there is no chemical reaction like in superglue (that would be a big no-go on electronic devices) - it melts with heat and hardens when it cools down - so no problem at all. but keep in mind - there are different hot glue's on the market - some need only 80°C to melt - others need 200°C - so using a glue with a higher temperature range would be better than ones with the lower melting temperature
这个答案有帮助吗?
得分 0
2条评论:
Thanks Markus,
Just for those that are interested, just completed this fix - now got full signal for both wifi and gps back.
If you're going to try this fix, suggest you spend some time looking at how the display fits back onto the base, I had to reshape the hot glue so that the display fitted back correctly...
完成的
since hot glue can be cutted or modeled - it is good to support problematic connections. nice idea that you had ;-)
完成的
添加一条评论
添加你的答案
Tom George 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,950
