跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Why won't my iPhone boot after replacing the GPS antenna?
Hi guys,
I have a problem with my iPhone, after replacing the GPS antenna (it was broken), the iPhone won't boot. When I switch on the iPhone the Apple Logo is shortly flashing on the screen, nothing else!
I tried a recovery without any signals on iTunes!
Any tips or ideas?
Sorry for my "english"!
Greetings from Germany
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Now i tried a restore on my XP Notebook, unfortunately, with the same result.
Oddly enough the device reacts only if the cable USB is connected.
When i press the power button for a longer time, the Apple Logo flashes every 3 seconds.
I am absolutely helpless!
完成的
添加一条评论
5个答案
最有帮助的答案
Greetings from the USA!
Try putting the phone in DFU mode and then doing a restore.
Unfortunatly there is no way to back up your phone right now so you will have to use a previous backup.
1. Connect the iPhone to your computer with the USB cable. Make sure iTunes is open.
2. Hold the Home and Power buttons for 10 seconds.
3. After 10 seconds release only the Power button and continue to hold the Home button until the phone shows up in iTunes.
4. Proceed with a restore and your phone should be OK.
The reason the phone may not be working is a conflict in drives/firmware of the new GPS/Antenna.
Hope this helps!
-Varsity
这个答案有帮助吗?
得分 1
1条评论:
I have an Windows Computer (WIN 7).
I try it with my XP Machine!
完成的
添加一条评论
I had a similar problem with an iPhone 3G I worked on- is there any water damage in the dock connector? If there is, that will prevent it from connecting to the computer.
这个答案有帮助吗?
得分 1
添加一条评论
Varsity,
thanks for your help!
No reaction, no device in itunes, only a short flashing apple logo on the screen!
Sometimes i hate my iphone.
这个答案有帮助吗?
得分 0
1条评论:
Sorry to get back to you so late. I try to answer as many questions as i know i can help with. If the phone has a spinning apple logo then something went wrong when you put it into DFU mode. Do you have Windows or Mac? Try restoring you iphone on another computer. This may just be a software issue.
完成的
添加一条评论
Josh,
no Problems with water or anything else, it works fine bevore i changed the GPS antenna.
这个答案有帮助吗?
得分 0
2条评论:
That's certainly a nice thing... water damage is very annoying, not to mention nigh impossible to fix. How slow/fast is the blinking?
完成的
if you press the Power button the Apple Logo is visible for 0.5 seconds.
I think the device cant boot while they have a not visible failure.
Yesterday I have measured the battery, since the device can be switched on only with cable inside, the voltage is 4.0 V.
完成的
添加一条评论
Sounds like. Battery issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ollih 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 4,210
