跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
MBP 2015 - Upgrade Storage from 256GB to 1TB?
Hi,
I'm planning on buying a 13" Macbook Pro early 2015 model with 256 GB storage.
I want to check, is it possible to upgrade the storage later. I might want to upgrade to 1 TB to run VMs.
Regard
-Dino
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 22
添加一条评论
9个答案
已选择的解决方案
Well I have good news and bad news here:
  • First the good news - Apple's custom SSD blade drive is a replaceable unit so its possible to swap-out.
  • The bad news here is its too soon to say when 3rd party replacements will hit the market as this system is just too new.
  • The other bit of bad news is largest SSD so far available is still very expensive and only 920GB in size. I would recommend you follow this site: Transcend they appear to be aggressive on offering options for Air & Retina systems.
I end with a bit of good news here: Intel and Micron’s 3D NAND promises SSDs “greater than 10TB” so in a few years we should start seeing lower cost SSD blades and larger ones as well.
Update (03/12/2016)
Good News! OWC has just released their SSD's for the Retina systems!
Here's the details: MacBook Pro with Retina 13" & 15" Late 2013 - Current
这个答案有帮助吗?
得分 17
2条评论:
Will apple swap one out with a nominal fee? i got 128gb..id like to go to 512.....idc to pay I'm just not sure if they do that sort of thing..
完成的
Sadly, Apple won't upgrade sold systems. At one point Apple did offer after sale upgrading (cracking open your system) a good five years ago they stopped offering upgrading. If you just bought your system (first week) they do offer system exchange just make sure your system is blemish free.
完成的
添加一条评论
I found the TarDisk, when I was searching the web on how to expand my macbook storage.
I ordered it and it came last week and has been working perfectly! It doubled my MacBooks onboard storage. Check it out!
这个答案有帮助吗?
得分 8
添加一条评论
Yes, you can. See theses links below : (if you are rich)
Aura 1TB Upgrade Kit (649$)
9toMac How to Video
OWC Digital How to Video
这个答案有帮助吗?
得分 3
添加一条评论
OK I just finished placing 1 Tera SSD in Mac Pro Retina 13 (early 2015) and it took me about 10 minutes.
The cost are: $13 for adaptor + $105 for SSD (1 Tera). According to stats it is faster in the Writing side now.
If you want details, let me know.
这个答案有帮助吗?
得分 2
3条评论:
What brand SSD did you use? Did you follow instructions from a video?
完成的
Can you give the link for SSD? I don't think that its that cheap.
完成的
Are you having any issues with wake from sleep or heating?
完成的
添加一条评论
Where can I find the SSD for my MacBook Pro?
Currently it has 256 GB and I need more space!
这个答案有帮助吗?
得分 1
1条评论:
For now your only option is using a SD slot drive like this: Transcend Jet Drive Lite to add storage. If you have a different model than the OP review the Transcend site for other options
完成的
添加一条评论
I currently have 8 GB RAM & 128 GB SSD in my MacBook Pro 2015, and I want to upgrade to 16 GB RAM & 1 TB SSD.
As far as I know, I can do that change, but I don't know what RAM & SSD I must buy.
Can help me with this?
这个答案有帮助吗?
得分 1
1条评论:
Sorry guy ;-{ Apple soldered the RAM in the Retina series of the MacBook Pro's so you can't upgrade it.
But! You can replace the SSD drive as it's socketed. Now the other shoe drops... The bad news here there still isn't any 3rd parties that offer the needed unit. Hang tight I hear some rumblings their might be an answer soon.
UPDATE Both OWC & Transcend offer great options
完成的
添加一条评论
I found a 1TB SSD for the 2015 MacBook Pros, as well as the Mac Pro... But it's $1300 :/
http://store.mcetech.com/mm/merchant.mvc...
这个答案有帮助吗?
得分 1
2条评论:
This company sucks! I ordered a 1TB SSD from MCE technologies a month ago (almost 50 days now). They never send product and never pickup the phone. Also never responded to my email either. Driving me crazy!
So I canceled my order to my credit card company and still waiting. Card company said need wait 50 days more!
完成的
did this resolve itself finally, StealthMarine? hope so!
完成的
添加一条评论
What can be done with the old SSD? I know there is only 1 external case for it from OCW that is pricey!
But, could it be mount into a Desktop PC motherboard? Is it standard?
这个答案有帮助吗?
得分 1
1条评论:
Yes Mehdi F, you can buy a PCIe adapter board to install it in a desktop PC. My motherboard cannot boot from the device so I have a small boot partition but once the OS is loaded the SSD works fine and is pretty fast.
完成的
添加一条评论
Hi there,
I’m hoping to upgrade my 13” Macbook pro with a 2TB OWC Aura SSD. Other than the actually replacement of the piece (I’ve watched a few videos, if anyone has extra pointers, that would be great too!), is there anything that needs to be adjusted, upgraded or anything in order for the system to be compatible with the storage? What are the risks to the system/computer if the SSD is upgraded with a non-Apple certified SSD? Any help is great!
Thanks!
这个答案有帮助吗?
得分 0
1条评论:
Hi! I'm planing to upgrade my early 2015 13" MacBook Pro to 2TB SSD as well. Did you do it? Is the 2T working ok? Not an overkill? Did the system recognize it? Most Youtube video upgrades are for 1TB SSDs; I wonder why they're not doing 2TB SSDs. I was afraid this is because of system incompatibilities.
Thanks!
W
完成的
添加一条评论
添加你的答案
Dinesh Velusamy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 33
总计 254,203
