跳转到主内容
A Wi-Fi and NFC capable CMOS camera first released in March 2013. Identified by model number EV-NX300ZBQUUS.
Why does the camera flash green but not urn on?
Battery installed. SD Card in and out.
Regardless of charger being plugged in or not plugged in, camera will not turn on but will flash green at the battery light.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Hi Aaron - did you solve this? I have the same problem.
完成的
添加一条评论
2个答案
Hi, Aaron.
First try to connect your camera to a PC and see if it is recognized by the PC; and if the camera shows any reaction. Based on your description, it appears not to be a power or battery issue. However, Samsung has identified multiple software glitches since release that, depending on how they manifest, may render the camera inoperable.
If the camera makes a connection with your PC, please visit Samsung's support page and update it with the latest software; this often restores the device. However, it the PC is does not connect with the camera, I would suggest to either contact Samsung support or, potentially, replace the damaged(?) motherboard on your device.
Hope everything goes well.
这个答案有帮助吗?
得分 0
1条评论:
how the !&&* can you change the motherboard ..brought from pc world you go in there and ask What der ???
完成的
添加一条评论
I have this problem also. It happened when I tried to update the firmware which failed to finish and now stuck in this contant cycle.
这个答案有帮助吗?
得分 0
1条评论:
we have the same problem after updated my firmware it won't finished and stuck with the logo of samsung even on or off. don't know how to fixed it.
完成的
添加一条评论
添加你的答案
Aaron Pena 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 25
总计 3,868
