跳转到主内容
Released in 2011, this phone is available on GSM networks with a 3.7-inch touchscreen, 1GHz processor, 3MP camera, Bluetooth, Wi-Fi, GPS and Memory card slot, additional camera. Model number: SGH-T679.
Why is is only one side of the audio playing
every time I plug up my headphones I can only hear the audio on the left side so I thought it was my headphones but when I tried my sisters and my brothers headphones I still couldn't hear any audio on the right side
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You may need to clean the headphone jack. It may have lint or dirt built up on the point that makes contact with the headphones plug. Which may result in a poor connection causing only one side of the headphones to work. Try blowing out the headphone jack with compressed air or clean the jack with 90% or above isopropyl alcohol and a q-tip or pipe cleaner or whatever small brush can fit in the jack. It could also be that the headphone jack is not making proper contact with the contacts on the logic board. You would have to open the phone to be able to see if this is the issue. If cleaning the jack doesn't fix the issue then the headphone jack may be faulty and needs replaced. There may also be a software or app issue causing the problem, which a hard reset may fix. Let me know if you figure it out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
len kagamine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 263
