跳转到主内容
A tablet released by Hisense in 2014, identified by model number E2281.
36 个问题 查看全部
Why does my battery not hold a charge?
I have been charging my device for the past five hours and yet it is still not fully charged. My outlet is working and I have correctly plugged in the charger but still nothing. What can I do to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
1条评论
The answer given does not fit the question. Your battery's suck. Just tell the truth about your product hisense
完成的
添加一条评论
2个答案
最有帮助的答案
If the tablet does not charge, try wiggling the connector. If the tablet continues to not charge or only charges when the chord is held in a specific position, then you need to repair the USB port.
If you are having trouble fitting the charger into the USB port, you may need to remove the connector and check if there is any debris in the port. If so, then clean out the port and try connecting the charger again. If the charger still does not fit, there is another underlying issue.
这个答案有帮助吗?
得分 1
添加一条评论
Your battery is most likely shot. Good luck finding a replacement. I suggest a different manufacturer
这个答案有帮助吗?
得分 0
1条评论:
Actually the battery is for sale online. I'm assuming you knowhow to open the plastic case without breaking it. Use a plastic guitar pick at the seam. The batt has numbers 606090 on it and it is 3.7volt 2400mah. And so obviously if your not tech inclined then dont attempt it. The batt stops holding a charge. It's a cheap batt they installed at factory
完成的
添加一条评论
添加你的答案
Katherine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,516
