跳转到主内容
Why is the iPod not charging?
when I connect my iPod to the laptop it does not show the charging light.My iPod is not working and I assume that its not getting charged is the reason.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Have you ever opened it? If you have I would check your contacts.
-Me-
完成的
添加一条评论
2个答案
已选择的解决方案
The shuffle is pretty old - most likely the battery died and when the battery is dead - the iPod won't react in any way when you connect it.
if you have a multimeter, open the shuffle and measure the voltage of the battery - if the voltage is below 3v - it won't charge and should most likely replaced (there are ways to charge those batteries - but since the shuffle battery is cheap - i would go for a new one)
这个答案有帮助吗?
得分 5
添加一条评论
I bought anew charge from Apple store, it was charges, but after (14 days retuen limited time!) it did not recharge! I lost $ for that (new) recharge, Can't not return it !!!
dondndavid@yahoo.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
puneet 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 17,426
