跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Is it possible to replace SMC and keyboard
I spilled some water on my macbook air and it stopped working. I got it checked and was told that there is water damage to SMC and Keyboard.
I can replace the keyboard, but is it even possible to fix or replace the SMC chip or my macbook air is useless now.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sounds like you're between a rock and a hard place here ;-{
So for starters you'll need to replace the complete upper case assembly (keyboard & trackpad included).
As for the logic board the chip is soldered to it and not easily replaced, Thats not to say it can't its just beyond most DIY folks (I don't even do it any more as you need keen eye sight). That then leaves you with the expense of replacing the logic board.
Between both costs and the labor it might be cheaper just to get a new system (used). Are you sure the chip is damaged and the logic board only needs be be cleaned to be it back working?
You might still be able to recover what you have on your systems SSD by buying this: OWC Envoy Pro Portable, Bus-Powered USB 3.0 Enclosure For Apple Flash SSDs (June 2013-Current Mac Models). Give them a call to double check.
这个答案有帮助吗?
得分 2
添加一条评论
Here is the video link how to replace SMC chip. https://www.youtube.com/watch?v=r1dFeGgL...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
M Rajput 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 6,932
