跳转到主内容
加入维修社区 - 创建账户
The Azpen A701 is a 4GB Wi-Fi tablet running on Android. It was released in July 2013.
Why won't my device turn on?
When I try to turn on my Azpen A701 tablet, nothing happens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
5个答案
已选择的解决方案
If your device won't turn on the battery of the device may be dead or below the critical battery level (About 15%). Try charging the device and turning it on again. If this does not work refer to the troubleshooting page for replacing the battery.
这个答案有帮助吗?
得分 1
1条评论:
You should not just immediately replace the battery. This may be an unnecessary repair that can end up costing money but not ultimately fixing the issue.
完成的
添加一条评论
最有帮助的答案
If the device will not turn on but you have been charging the device, then the problem might be your charger.
Try using a different charger to charge the device. If the device still does not turn on then there are many possible other problems that can cause this: Some of them are fixable while others are not.
Like Grant suggested, it could be a faulty battery in which that can be replaced.
Also, it can be a software issue. In this cause the device might be "bricked" which means that the device is missing necessary files in order to boot and fails before initializing the boot up process. If this occurs then you may way want to contact the manufacturer and talk see if they can repair the device.
这个答案有帮助吗?
得分 2
添加一条评论
how long shoulod i charge it?
这个答案有帮助吗?
得分 1
添加一条评论
I had my tablet charging for about 3 hours then it would not come on. Thanks to Daniel, I figured out it was the charger that came with it, that was the malfunction! I put it on my Android phone charger and now it's charging from 0%! I'll let you know if that completely solves the problem with my A1040 not turning on.
这个答案有帮助吗?
得分 0
添加一条评论
i put a laptop charger
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 43
总计 3,278
