跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
Screen is unresponsive to touch in a horizontal strip
My iPhone 4s has developed a dead spot that is unresponsive to touch input. The strip is about 1/4" in height and extends completely across the screen, at about 3/4 of the way up from the bottom of the screen. I have also had occasions where the entire screen became unresponsive when the phone was only mildly cold (like in my pocket on a 40 deg F day).
Thinking that the digitizing screen was at fault, I tore down the phone completely and replaced the display/digitizer assembly. This was partly successful, in that the screen and new digitizer work... but the dead strip remains. I am guessing that this is a problem on the logic board. I doubt that it is the connector; my cold temperature experience seems to point to the solder joints of the digitizing chip on the logic board. What say you?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi,
I have a Iphone 4. I have just changed the dock connector. When I restarted the Phone, I had horizontal strips on the screen, black and white, The cell works, it's receiving phone calls, I can speak, SMS are taken, we heared the little music. The touch screen is working, I think so.
I don't know what is happened.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Klieb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 656
